Butch
Poseur
- San Jose, California
someone posted Bryan's vid
on our site
Can normal folks get Red Tube? Is that a porn site?
on our site
ah, you be in Utah, prolly not worth the shipping. Unless... dont tell anyone but I used to ship all sorts of stuff from my work for free. I retired nine years ago, so i guess its ok. Thanks.Do you want mine? First thing I'm going to do is pull them out of my bike before I even ride it.
guy on BARF (a BARFer) wants them. He’ll pay shipping. is the rear 18 or 19?ah, you be in Utah, prolly not worth the shipping. Unless... dont tell anyone but I used to ship all sorts of stuff from my work for free. I retired nine years ago, so i guess its ok. Thanks.
Actually, I'll ask the guy on BARF if he want to pay shipping and handling...
They be like anti heavy duty, eh?
I don't have my Varg yet. It's currently in a shipping container on it's way across the Atlantic. Remind me in a month or so when it arrives.guy on BARF (a BARFer) wants them. He’ll pay shipping. is the rear 18 or 19?
I hope your kids can swim or touch the bottom!My kids use them as a floatation device for the pool. Problem solved.
Haha they canI hope your kids can swim or touch the bottom!
(Risky bidness relying on those flimsy tubes to hold air).
Yesterday, when I was unloading the bike from the trailer after a trackday, I noticed that the valve stem of the front tyre was very crooked, like 45° from the radial direction that it is supposed to be pointing at, and that the tyre had very little pressure. I was able to inflate it and it held air for some minutes, so that I was able to unload the bike and put it on the stand.I have had two stark red tubes fail at the valve stem. Just a small enough hole to not hold pressure. At that point, I will stick to traditional tubes; not worth the energy. I am sure stark future would replace them at no cost, but the downtime and inconvenience is not worth it in my opinion. If you are hitting the track and sticking your landings the last thing you want to blow out the tube and bend the rim. These tubes might be nice for casual riding on the trails. But that being said my first front red tube valve stem failed on a normal size rock. And yes wheel locks are always checked and seeded to the bead; no angle in the stem.
Do yourself a favor and replace the back one as well.Yesterday, when I was unloading the bike from the trailer after a trackday, I noticed that the valve stem of the front tyre was very crooked, like 45° from the radial direction that it is supposed to be pointing at, and that the tyre had very little pressure. I was able to inflate it and it held air for some minutes, so that I was able to unload the bike and put it on the stand.
The rim lock was tight and the pressure had been set pretty high the day before, so I think that first the tyre deflated because of a tube failure and then it started sliding on the rim while I was braking, bending the stem. Years ago I tried a friend's bike on a track in similar conditions, a little muddy, and I didn't realize the front tyre was flat, so I guess I didn't realize it this time either.
Today I have removed the tube from the tyre and if I inflate it, it will hold air for some time without any hissing sound. I didn't look for the leak carefully but I just poured some water at the bottom of the valve core and it doesn't seem like air is leaking there.
The rim dosen't look bent but if I feel its side with my finger there are a couple of spots which feel slightly bulging.
Even after having re-inflated the tyre, after it deflated again I was able to break the beads just with my fingers.
I haven't managed to remove the valve core because if I turn it, the whole valve spins in the red stem.
I will replace that tube with a conventional one.
So have you been able to remove the core of the valve stem to pour the sealant? On my front tube the core just spun with the valve inside the red stem.I had 2 pinholes in the front tube and 1 in the rear after the first ride. If I hadn't put tyre sealant in the tubes before the first ride it would have been a quick ride.
C | Varg broken out of the box Red light constant | Stark Varg -- Discussion | 27 | |
G | Stark Varg charger housing kit | Stark Varg -- Discussion | 11 | |
Eddie Karlsson Stark VARG GoPro | Battle of Veklings Extreme Enduro | Videos | 1 |
