- Connecticut
We should start keeping track of the error codes and what they mean.
Code 007 - Battery isolation -- Reference: Code 007 isolation
Code 32 - Service Required -- Reference: Error: Service Required Neg Weld
Code 33 - Service Soon -- Reference: Warnings on dashboard on new MXR
Code 34 - Service Required -- Reference: Error: Service Required Pos Weld
Code 35 - Service Soon -- Reference: Display Functions and Firmware Version
Code 36 - Battery Fault -- Reference: Code 36 service required??? Per ex-Alta employee "It's a voltage imbalance within one or more of the battery modules. It indicated a possible interrupted connection between cells, a fault within the battery itself."
Code 37 - High humidity within battery pack -- Reference: code 37 high humidity in battery pack
Code 103 - Battery won't charge -- Reference: Alta Fast Charger, and also 2018 Alta fault code 103 second time
On the Display - Negative Contact Relay Failure -- Reference: MXR Negative Contact Relay Failure
On the Display - Cycle Key To Erase Battery Error -- Reference: Cycle Key To Erase Battery Error
On the Display - External Charger Fault -- Reference: External Charger Fault???!!!
On the Display - Inverter Throttle Fault -- Reference: Inverter Throttle Fault
On the Display - Service Required Pos Weld -- Reference: Error: Service Required Pos Weld
