- Lake Havasu City, AZ
I built this for a friend in about 6-7 weeks. It started life as a 1991 KX80, was converted to big wheels some where along the line. My friend put new tires on it and had the suspension gone thru. Gave it to me. Now after he get it back, he is going to ride it a bit and the tear it down and powder coat the frame after all the work.
@Mark911 challenged me to a PIT BIKE race, but I think the owner is going to take it too soon, he is excited.
After some research I found Electro and Company (ElectroBraap) for the hardware and controller programming. They have bolt on kits for other pit bikes, but not for this model bike, so I had to build my own mounts and battery. They have a beautiful kits for 2002-2018 YZ85, and another kit for 2002 - 2016 KTM 65 SX. But they sell motor-controller-wiring - programming kits that work great.
We purchased a QS 138 70H V3 motor Controller kit, with there (Electro) programming, a wiring harness, with throttle and switches. I comes with a Chinese display that is cute, but not real useful. This kit made the conversion sweet and much simpler.
I'll put a few pics in here, but I took a lot and videoed a lot. If you want all of them, EM me and I can find a repository for all of them or a CD or USB stick. I also have the templates for the motor mounts and battery box. I am going to get some of these water-jetted or Plasma cut, and the battery box case we can talk about it f you are interested. I chose Molicel 21700 cells in a 20S8P config. The motor /controller only draws 210-250A, but for longer ride time I went to the 8S config. I used an ANT 300A Smart BMS. Man that is sweet also. I got most everything from ElectroandCompany.com, except the cells and battery cell holding brackets.
The Bike weighs 175lbs. the motor gear reduction weighs 28.5lbs, complete battery 30lbs. It is so fun to hop on and go, but in Warp mode (15KW, 20HP) the front wheel isn't on the ground very much. It has 3 speeds. ElectroandCompany.com added their programming and it is so plug and play. Th ANT BMS is so smooth and you can look at all the Battery vitals.
Cost is in the range of $3000 to 4000 depending on buying a battery or building a battery. (Not including the donor bike) Motor / controller $1300, Battery parts $1500 ( that's including a 15A charger. Electroand Company gets somewhere near $2300-2500 for there same size SLR3.2 with charger, and that is a good price, knowing how much work goes into one. Theirs wouldn't fit in my frame.) And a motor mounting kit and battery box maybe $300 to 400.
The bike didn't look symmetrical with only one radiator shroud, so I found a 2020 KLX110 bike had a mock radiator shroud. So I got one and it fit with a little work. Definitely looks more contemporary.
![IMG_1030[1].JPG IMG_1030[1].JPG](https://electricdirtriders.com/data/attachments/7/7701-ac3af239671aed493b138314eae8598d.jpg?hash=rDryOWca7U)
![IMG_1687[1].JPG IMG_1687[1].JPG](https://electricdirtriders.com/data/attachments/8/8363-f12d0bcf76b9a09d8725dfc3eb6451a4.jpg?hash=8S0Lz3a5oJ)
![IMG_1888[1].JPG IMG_1888[1].JPG](https://electricdirtriders.com/data/attachments/8/8366-6403199515bb5d0c45f2f58f9a237642.jpg?hash=ZAMZlRW7XQ)
![IMG_2667[1].JPG IMG_2667[1].JPG](https://electricdirtriders.com/data/attachments/9/9032-40abe23ef46b60a22cbccf511313582c.jpg?hash=QKviPvRrYK)
![IMG_2508[1].JPG IMG_2508[1].JPG](https://electricdirtriders.com/data/attachments/9/9034-4b53d11a03ce00197d992e41276e7769.jpg?hash=S1PRGgPOAB)
