- Lake Havasu City, AZ
If it is the exact same charger, would we be able to use our Alta chargers with the Varg? Is this Elcon charger smart and capable enough to generate a higher ~400VDC charging voltage for the Varg's battery… if the bike asks for it... politely?As far as I'm aware, Stark is using the same exact charger for the Varg. If i find out otherwise, i will certainly let you all know.
@TCMB371 @fsfs
