Dave, I tried some battery combinations in the Honda bike I have here. Just some test fittings. If you go back above, and look at IMG6656, the side view of the Honda. you can see the space below the battery in front of the motor, I can fit a 6 cell by 8 cell pack in there. Then I made another pack to go with that of a 8 cell by 14 cells. This would be the bottom pack, these 2 together, 6 x 8, and 14 x 8 for a 20S8P lower pack. Now the top pack would be a different shape but also 20S8P, but 2 rows of 10S8P side by side. Here is a sketch of the two packs. The top pack we would need to test the shape to see if it fits (7"wide, and 7.5" front to back, and 9 tall. We can come up with different shapes. (IMG 7293)
I have made a lot of batteries, but now I prefer having them built by Amorge. There is a lot of labor in building batteries, and the cases that Amorge makes are really a work of art, solid and watertight. But in building a battery, you want the cell groups to line up next to each other, or it gets real complex. Here is a pic of a battery I make for KX80-100 conversions. You can see the straight cell groups and then the weird shape cell groups. Those make it more complex. This is our fusible link battery packs that we make. (IMG5791)
Anyway just some ideas. Here are a couple more pics of the test fittings on this Honda.
For reference, here's how the battery for my 250 is laid out:
It's 20s20p with 18650. Disclaimer: I haven't actually tried putting it in, as the design was made by the person I bought the project from mid-way. Supposedly the test cardboard model they tried did indeed fit. I want to make the case for it out of fiberglass and mold it as close as I can, but I expect there might be some "finessing" required to make it fit. I also need a way to build some kind of bottom support.
Yes building the battery is tough. You make mockups and it all fits, and the final product is always a little too tight. I am finding that Amorge can build to very exact specs for the outside dimensions of the battery box. They can tell you how many cells will fit, and they make a nice aluminum box for the battery. I think the same shape battery could be built with 21700 cells (Molicel P42A) at a lot lower cost. I have built 18650 batteries out of Sony VTC6 cells and they are still in use, but the cells are more expensive and many more connections. Do you want to build the battery yourself, or have it made for you. Here are a couple custom Amorge battery's (20S12P P42A Molicel) they have made for me. If you read the label on these 2 batteries they show low Continous Discharge, but this is the BMS limit, but we have them made with Open Discharge, or no BMS control on Discharge , only Charge control. The Motor Controller has our low Voltage Slowdown and Shutoff. We can and do get 400A's out of these packs. I run most of the time at 300A. 72V at 400A give us a good 28KW. 28KW can keep up with the gas bikes, up the big hills at Glen Helen. This size batteries can run 6 lap races on that track with a half battery left.
thanks to all of you who contributed knowledge and info
I guess I made my mind now.
not saying that I have decided on a specific battery yet but I have a plan now that I will follow :)
my absolute Dream Battery is this one:
EWATT 72v 76AH Pouch Cell Battery
Dimensions (mm):225mm x 177mm x 373mm
Dimensions (Inch):8.86″ x 6.97″ x 14.69″
300amp continuous power and 600amp peak
Capable of 42kW peak (21kW continuous)
there is even a 80v Variant of it same dimensions with:
Capable of 48kW peak (24kW continous)
I made a Cardboard dummy to see if I can get it in somehow
Due to the dimensions putting it in from the top will not work.
Ill give it a try to take out the motor slide the battey in from the bottom and put the motor back in.
Thats then a more or less "permanent" battery but its huge and has a lot of juice plus it is capable of charging at astonishing 50A
So every brake from riding it can get charged up quick again (20A charger is included with the batt I guess thats plenty already don´t think its nessesary to go higher than that)
In case I cannot get the EWATT battery to fit I have to go the Amorge route.
72v, Metal Casing, QS10 Plugs, Open Discharge, and as much AH they can put in with Molicell P42A Cells overall min 300 amps continous
I have 2 Dimensions other dudes whare able to put inside their 2006-2009 CRF 250 Frame:
CRF 250 2007 Amorge 72v 44AH 330amps continous
25"x6.25"x6.25"
63,5cm 15,8cm 15,8cm
ran it up into the tank
Little surprised that he only got 44AH with this big boy battery.
2024_10_29_10_14_34_2007_Honda_cr250r_new_life_as_an_Electric_braa_east._YouTube_Mozilla_Firefox.jpgUnbenannt14.jpg
Amorge 81V 60AH 220amps Continous Samsung 50s Cells
155mm x 165mm x 460mm (370mm on the short side)
6,1" x 6,4" x 18,1" (14,5" on the short side)
They are both for sale near by but I really dont wanna buy anthing with Samsung 50s Cells but Wondering what power Molicells in this dimensions would deliver.
Longer tip goes down in front of the QS motor.
sadly have to wait until the weekend after next to see my bike again and start testfitting....
but at least I have fun building cardboard dummys until xD
Mine with Sanyo cells will be similar capacity. The easiest way to get decent kWh ratings regardless of voltage is to simply use better cells. With higher voltage the currents can drop slightly, so large pouch cells like e66a can often be enough for the target power. When you want really high currents, the 21700 cells from Molicel offer the best performance right now, but the price of a battery built with them can be easily double or even triple of a battery with a cheaper cells, for like +30-40% increase in capacity.
And then there's weight; while it's fairly easy to add more parallel cells to get more current and more capacity, especially when building a custom unit, adding extra 10kgs will be definitely felt in harder terrain. My current plan is to set the bike up with this relatively small ~3kWh battery, and see how much effective range I'm getting, as well as how much power I'll end up using. Then potentially plan for a second battery with more capacity and power (and likely voltage too) if needed. Even f I built the exact same shape with Molicel 18650 cells, I'd still get about +50% in capacity and similar power ratings.
25"x6.25"x6.25"
View attachment 12144View attachment 12145
View attachment 12146View attachment 12147
I've been looking at those same Ultra Bee batteries. The 80v 76ah from Ewatt. They also have an 88v option! Chi Battery Systems also has one coming out soon.
So, this is a question for Don (or anyone else in the know): What do you think of running these higher voltage batteries?
I guess it would be a matter of using the right controller with it. But I know the QS138 70h V3 motor can run higher voltage, so that would be more ideal, correct? Less heat build up, and would be able to run lower amps. If one were to go with a battery like this, what is the best controller to pair it with? EBMX maybe?
I love my YZ build, but would like to run a little more power for MX and have a little more range for off-road. The simple solution for me right now would be to just get a second battery. The problem is that the power drops significantly after about 15 min of hard MX riding with my 72V 51ah battery at 350a. That's closed to a full local amateur moto anyway, but I'd like to not have to worry about swapping batteries and would rather use, perhaps, 50% charge in those 15 min, then throw it on a charger back in the pits. I feel like that could be achieved with an 88v 76ah battery while running higher kw and lower temps.
Thoughts?
@bayodome at least in my situation I have to stick to max 81v battery’s since my x-9000 controller can only handle up to 95v and a fully charged 88v ewatt battery has up to 104v so that crashes the limit there should be a 3sul something and a big fardriver controller that are capable of handling that much power
Great point there. But yes I've heard good things about the 3Shul too. I'm no programmer, so would need to find a way to get the controller working properly with the motor.
The 3shul are VESC based. VESC is a very pupular and friendly line of controllers.
Easy & friendly to program. these are high quality controllers.
The 3shul are VESV based. VESC is a very pupular and friendly line of controllers.
The VESC based controllers are very easy to program. I've personally programed several VESC Controllers/Brushless DC motors. I hope Votol moves to a VESC control in the future.
The battery is definitely the greatest challenge in the process. Attached is what I have come up with as the easiest configuration for a drop in/quick change 20s 12p 72v 50Ah battery. This drops right in my 2011 CRF frame. No grinding and no cutting required.
Here is a mockup of version 2 battery with the cells positioned vertically. This layout allow 280 cells for 20s 14p. The 2010 true 2013 CRF 250R frame is just too tight.
so lets continue....
TX Race Restyle Plastic Kit is awesome:
Controller fints just perfect in the Airbox:
Cables will be fed through from below through the hole from the Carb Side.
Battery still gives me a super hard time...
to Fit anything in there the TOP motor Mount Bracket needed to be Cut off:
Above Box Size: 155x165x460 (370mm on the short side) Measurements taken from an Amorge Samsung 50S 81V 60AH Battery:
2024_11_12_10_27_57_Surron_E_MX_Moto_Cross_Akku_Batterie_81V_60Ah_Kart_ebmx_bac_in_Niedersachs...png
Since I want my Battery in a Metal Casing and other Cells I took some measurements with the Cardbord box in the Frame and came up with this Sizes as ok Max sizes with a little bit of play:
and that size is exactly what I emailed to Amorge to get an offer for:
20S?P or 22S?P
Metal Casing
QS10 Plugs
Open Discharge (BMS Only for Charging)
Molicel P45B Cells
Battery Leads
10A Charger
had to wait the weekend patiently for a reply but sadly my Shape isn´t possible for them :eek:
they cut away the lower little square:
and where able to put:
20S11P or 21S10P
The price is: 1489USD
yikes thats a little too less Parallel´s as I hoped for....
and I never asked for 21S as my Controller does not really support this (just with workarounds but I don´t want that.)
20S and 22S is preconfigured tho.
anyway so I had to take out my measurement tools again and now went for "tight fit max out" hopefully shapes Amorge can work with:
Option A
Option B
the angled top follows the flow of the Gas Tank to really max out any avaialbel space (still left room for Cables coming out on top of the Battery)
desperatly waiting for a Reply from Amorge but didn´t got one during last Chinese Businessday...
we will see I will report.
Custom Graphics just arrived the "CRE" will look killer:
@fmxxx666
Have you discarded completely the option of using two batteries? Aside from the fact that there would be more surface to exchange heat, it would be easier to fit them taking advantage of the available space. Making an extravagant example, if you filled that space with cells without a case -which you can't do for obvious reasons- you would be able to fill almost all the space available and also to move them in order to balance the weight distribution. One single big battery which barely passes through the frame when you install it probably gives you very little leeway in those regards. Two batteries would be a compromise, though they would cost more than a single one.
@Theo
yep that Idea was never really an option for me as I am not building the Battery myself, I doubt Amorge can do that. with one BMS connected to two battery housings or even worse two bms.
In the end the plan was to have it swappable slide in and out from the top.
the Plastics and the Tank will be mounted with push locks:
2024_11_12_13_11_06_1_Stück_Universal_Aluminium_Druckknopf_Billet_Schnell_verschluss_Rennwagen...png
So with the push of 4 Buttons I can take off Tank incl plastics right left and Seat.
this should make for an easy battery swap in case that one battery wont give me enough range / ride time.
Plus I dont wanna let the Battery in the Bike all the time since its getting super cold here in Winter and where the bike is stored.
@Theo
Love the idea of the push lock! That will make battery swaps so much easier. Might have to integrate that on my YZ build.
What kind of range are you aiming for? I'd guess that at 81v 60ah you'll be able to comfortably get 30-35 miles of trail range (depending on the terrain). On the track you'll be near 25-30 min of flat out motoing.
@bayodome
I am a super chill amateur I just wanna have fun with the buddys on a saturday at the track.
I don´t do trails only MX Tracks
With the Bike Build I have (same Controller same Motor) and a 72V 55AH Battery a dude with a bit better skill then me was able to ride
4x 15 min at the track
or
3x 15 min deep sand track
With beeing able to charge when making a brake I would think this could get me through the day.
If I see I need more to have a full day fun I would buy a second battery to swap around.
Just installed the Plastics with the new decals 😁
Still a ton of parts to install until the battery is here...
-New Seat Cover (dont like the look with the TX-RACE logo on it)
-Left Hand Rear Brake Line (getting rid of the foot brake)
-Black Stainless Steel Screws for everything
-Black Brake Disc protectors front and back
-Ton of other little bling bling parts
-Black Swingarm
once the battery is here and mounted I will go to our Suspension Guru and let the whole bike setup for my middle aged Dad wight xD
Probaply getting new springs for the forks and shock 😅
View attachment 12231View attachment 12232View attachment 12233View attachment 12234
View attachment 12240View attachment 12241
View attachment 12236View attachment 12237
20S?P or 22S?P
Metal Casing
QS10 Plugs
Molicel P45B Cells
Battery Leads
10A Charger
20S11P or 21S10P
Option A
Option B
View attachment 12244View attachment 12245
Thank you for the great post! Please keep us updated once you receive the pricing and final configuration for the battery. We are all fighting this same battle trying to get the most battery in the available space. -- Best, Dave
