Spam Assassin
I'm not so sure about that. For the last few decades it was nearly impossible for small mfg's to build a bike that complied with regulations. However with E propulsion there are way less hurdles when it comes to emissions, sound etc.
So in my total inexperienced take there is more room than there has been for a century to build and sell bikes by small mfg's.
I would love to see some small company like yours go for the sky though. A bit like Stark does now outselling ''the big 4'' in MX land.
As a small mfg we need to focus on becoming a big mfg, other players will come, you can count on every OEM having a bike for the eMXGP in 2026. There will be consolidation.
We need to swing for the fences, small garages retrofitting stuff won't be competitive in the new world. That's my take at least.
Would you be aiming for MXEP as well? I guess it could make wonders for brand awareness, especially for a startup ?
Hadn't been paying attention to flux instagram for some time, great stuff 👍
Development seems to be going well with talk about Primo 2.0 and aiming to start deliveries about a year from now.
And absolutely terrific photo
Swank171
Thought i would BUMP this thread. Just wondering how things are going. Seems some industry wide battery breakthroughs are happening!! I’m sure they are still too expensive to put into production but its always exciting to see what’s is coming!
Marko_Flux
Slovenija
Thanks for the bump!
We finally crossed a major barrier and will make an announcement soon, so good times ahead.
Battery breakthroughs are routinely oversold by the media to generate hype, in the real world there's no doubling of range on the cell level coming soon. Progress is relentless though, every 1-2 years there's a step forward. But we look at what we can do better than others on the same market, to have range advantages using the same cells.
Stay tuned!
Looking good
@Marko_Flux: I've noticed a mistake in your website: the battery capacity is stated as 7,9 kWh and not 7.9 kWh. I tend to make the same mistake since in Italy, too we use commas as decimal separators.
Now you just have to travel a little more westward to Ottobiano and bring a Primo SM with you, so you can teach those knee dragging younger generations how it's done! Remember the good old times? 😎
Marko_Flux
Slovenija
Depends on who you ask, in Europe it's comma, in the US it's dot. You knee-dragging, front-only-braking kids definitely need to get it sideways a bit more, life is too short to not be backing it in :lurker:
Would that riding style be somewhat possible with an electric?
Marko can surely explain it better or correct me, but here is what I do to drift:
1- I apply rear brake to squat the bike
2- a fraction of a second later, I apply the front brake, that I'll keep applied up to the apex of the corner, to keep the bike sideways
3- aggressive downshifting, like 2 or 3 gears one after the other, to have a lot of engine braking
4- hold two fingers on the clutch enough to have much engine braking but not so much to have chatter; the rear brake contributes but I don't lock the rear wheel because if it locks, I'll lose control. I have never used slipper cluthces
5- as the drift ends, I gradually release the clutch completely and start applying throttle again
Here is a video I recorded during a warmup lap in which you can clearly see that a drift happened without even touching the rear brake:
I guess that with an electric dirtbike you could potentially put it in a drift mode in which the rear wheel will have a precise amount of slippage and you don't even need to apply rear brake. I expect it to be easier than with ICEs, in general, if you can adjust regen braking.
To me, the regen braking of the Varg in the dirt feels too weak, though, to drift on asphalt.
The Primo has a sort of electronic clutch that behaves like a variable regen brake, which sounds even better for that purpose: @3:39
BTW it's a privilege to discuss drifting with Marko: how many of his videos I used to watch back then...
Marko_Flux
Slovenija
Theo you can try your luck with translation on an article I wrote a thousand years ago: Tehnika Slidinga: Kako počez??
Anyhow, yes and no. The motor gears bring a minimum speed component that isn’t present with a constant regen brake. We have a minimum spin speed that works great off-road, but doesn't work well at all speeds in SM. If you have wheel speed sensing on the front, it's relatively easy, you're chasing a slip % between the wheels, which can be a variable component maybe on the regen lever (sort of like a hybrid speed control alongside the baseline torque control). Generally wheel speed sensing at the front is prohibited in off-road racing (SM included), at least by the FIM. Maybe a reverse flywheel effect, combined with some speed control component, I don't know yet. TLDR, there's some work to be done.
Now track SM is very low on the market size list for these bikes, consequently also on the priority list, BUT...given my background, you can consider this my passion project and I will work on making it work.
Thanks for your detailed answer. I would assume Enduro market is much larger than MX in turn much larger than supermoto.
Would you have any ballpark figures for those? IIRC O'Neal CEO quoted about 80k annual MX sales worldwide.
Marko_Flux
Slovenija
About 5-10k per brand, per displacement for MX. Enduro is definitely big, if you can capture it with a single plaform, that definitely helps CAPEX a lot.
We'll send updates on activities, now our team is growing and we can do all of it way more effectively. Euro test rides are under way and it's great to receive feedback from future customers, to help guide the development.
Austin TX
markhamr
blaxlands creek australia
This bike seems to be heading in the right direction .
I would love to get my hands on one .
I like the feedback you are giving too marko.
Please feel free to contact me hopefully a bike
can be made available here in Australia.
It seems to address all the things that riders want.
Removable battery/ light weight and a company
that seems to want to improve the breed.
rs911
Sorry to kill your hopes of a lighter ebike but I'm 99% sure the bike won't weight 112kg like advertised on the first post.
The first message was posted on October 13, 2021 and you can't edit a post after 10 days for known members on this forum.
In October 2023, this website said 122kg, even 2kg more than the EX.
In the meantime the battery grew from 7kw to 7.9kw so the battery won't be lighter, at best still 34kg...
Well since the Primo is merely intended to be the base for the production model there's no point trying to predict the weight of a production bike that does not yet exist.
It's probably not easy to make it lighter than the Varg, although Marko wrote in the other thread they could consider offering a lighter version with smaller battery (removing a third of the cells to shed about 10 kg while reducing max power and battery capacity from 7.9 to 5.2 kWh).
The swappable battery looks particularly interesting thanks to the ability to charge independently from the bike.
markhamr
The bike is too heavy.
115kg is the magic number.
Looks like it is back to the gas bike for now.
Someone wake me up when a manufacture can make
a reliable e bike that fits basic parameters.
5.2 kw is not enough power so i would not bother with that.
It would need around 6.5kw to be any use.
Removable battery is a good idea,
that frame looks heavy though.
Spam Assassin
The frame is pretty much a Yamaha one from what i understood. But for E you would need a specialised one, and that's quite hard for a small company.
Stark had the "luck" that the starters are wealthy and had big connections.
