fmxxx666
- Hamburg Germany
haha after reading your long post I feel stupid xD…more amore’ for Amorge
I sent like 3 mails forth and back with Amorge (always gathering tons of infos for each to not waste anyones time) as I thought they are a company that only as a sidehussle deals with private annoying customers... so I was afraid of going on their nerves with more and more designes and questions.
But good to know that they are flexible in this regards.
regading the charger, dont stress too much about that, they will put a correct one suiting your battery in there.
if you open up your charger there is a knob you can twist to adjust the output voltage
But anyways so they have these "dummy" chargers lying around and adjust it for each battery they ship out.
On mine (for a 81,4V battery so the output voltage of the charger is: 92,4V) they even forgot to adjust the Fiber Laser that engraves the specs on the charger so it still says 72V 10A but output is 92,4V 10A
but you will most likely anyway buy a faster better charger later.
This one comes for free with it and its ok to start with.
Regarding the Cells I would recommend P45B or if you can afford P50B
I personally know 2 persons owning a Pack with Samsung 50s Cells and they both wish they would have chosen other cells.
One has even sold his whole bike and battery since it was impossible to ride on the Track in Summer for a decent time before the pack got too hot and shuts itself off.
And I am speaking of Germany Summer (28C / 82,4F outside tempreature) no Texas Desert Heat xD
I guess its better to have high quality cells that lough about the power you are pulling as cells that are constantly at their limits trying to serve you but at the cost of heat, cutoffs, and short overall lifespan.
my battery is capable of 585Amps at 81,4v but I am only pulling 350Amps on my highest setting currently on the controller and that is plenty of power already so the bike is beyond my physical handling limits already and I use it in mode 2 where it has 300Amps. (My controller is capable of 500Amps but that would be rediculus)
So I guess I am ok with one QS10 Plug but in general the higher the V the less you need the Amps for the same Power.
In case your controller can handle more you might also think about going higher than 72V if possible.
while we are talking about Plugs I would ask for an XT90 plug on the charging side of the battery the bigger the better.
I am surprised they even offer the XT60
Regarding shipping:
man I was so stressed xD
Me and another user here ordered our batterys only two days apart from each other (me 2 das earlier then him).
he ordered with sea shipping and I ordered with expensive air shipping.
and guess what he recieved his battery 2 weeks earlier than me...
but that seems to have been a lucky situation like Battery arrived at the harbour and there was a ship going next day.
can happen that is stays 2 months at the harbor waiting for the right ship sometimes.
so I was of cause a little dissapointed paying like 360 bucks for shipping only to recieve it 2 weeks later than someone who paid 160 bucks for shipping.
All that on top that you get zero updates on the shipping process after you pay.
A tracking number you earlierst get once it arrives in your country not before.
Ordered mine on 15. november 2024 and got it on 13. january 2025 thats hefty for air shipping...
but yeah christmas and all that sh*t was in between.
Regarding open Discharge:
I went with open discharge but after a long thinking process.
If you are willing to take the risk it will benefit you with no BMS cut outs and no BMS heat while discharging.
But you have to setup your controller to cut off or reduce power on the low end V limits of your battery to protect it from overdischaring.
And you wanna be extra secure with a fuse between battery and controller (as near to the battery as possible) in case there is a short in the system there is no BMS that sees that and cuts the power!
oh and whatever the design is and the exact measurements
in the end the battery you will recieve will vary a bit here and there it won´t be like dead on point with the scatch you approved.
on mine it was a few CM less on one side and a few mm more on another edge all managable but unexpected.
but since you left enough room to make your own metal box you should be fine
