EX Custom iOS/Android App
brongle
WA
Could you take a look at the battery sells if they're all the same or also 2 0's?
His delta V is so low I assume his cell groups are reading normally. Really does seem like your pack has two cell groups out, still very surprising to me that doesn't trigger a BMS fault or other warning on the display.
Everything works well for me on mx
it's strange only with the version in the stark application it shows 1.2.0 in your application 1.2.8 which seems to be true since there were no more updates
There is a versions page in the service menu that displays all the firmware versions for things, its possible I'm using the wrong one for the MX series.
I have 2 MX bikes, and I had a couple of slightly lower cells on the one that just got a new battery (but the battery percentage was below 30% at that point).
The lowest one was 3.917 and highest was 3.947 (.03 delta).
After charging the battery pack up into the 80ish percent, the delta is .01, and all cells are shown as green.
brongle
WA
FWIW I assume the pack layout is the same so its very common for the first, last, and middle two (50/51 in the app) cell groups to be farther out, these are the ends of the two pack halves so they dip a bit compared to the others. Anything below .015 on a full charge I would consider very healthy. Personally I do a balance charge when it gets past .02 but thats overkill, .040 is probably a better threshold to balance at.
Super, my 100% is around 409V just after charging. Will look again tomorrow morning.
Yea that pretty much confirms it, pack should really be at 410v or above and even that low of a voltage would imply maybe 500+ charge cycles. My EX pack (obviously different cells) is only down about 1v at 100% SOC and thats after 4000 miles. Good luck reaching out to Stark hopefully they do the responsible thing and warranty the pack.
I don’t know how the internals work but two cell groups missing seems insanely dangerous to just ignore unless they have some common failure mode they feel safe ignoring.
brongle
WA
An updated version of the app is now available on both platforms for testing, only two main things to test here:
- Updated the dashboard screen for Android to fix the speedometer overflowing and a few other spacing/display issues.
- Reworked how the underlying recording format works to make it much more efficient, recordings now store about 1mb of data per hour of riding.
If you'd like to expore the recording format more, I've also published a very early version of the simple browser-based software for viewing the recording formats at Svag Viewer. As I mentioned previously all the data processing is done in-browser and remains local on your device. Support for automatically recording rides and improvements to the viewer will come later down the road, for now this is more a proof of concept and helps me identify how people might use this in the future.
Thanks again for all the testers and feedback, I'll keep chipping away at the Android and smaller-screen layout issues.
Hinkelstein
Great! I can test it tomorrow. Do you know if it is the normal update procedure on android or ist it anyway special?
UPDATE: I updated via play store and now my app version on android is 1.2.0, native build 18. Is that correct?
