Honda CR-E vs. Alta Redshift
More like they had the same assumption we had in the beginning (early MXR issue aside), which is to set up the suspension based on an ICE bike.
Could you please elaborate about this? I heard Derek say that the Redshift's suspension should be setup differently because of the different power delivery, but he never said how differently exactly and why.
I have my guesses and theories, but I would like to hear the official version.
Judaslefourbe
Brisbane, CA
The ICE creates momentum that affects the suspensions in a big way. An electric motor does not have that momentum, so the suspensions have to deal with a "dead weight." Back in the days, we used to call that the "dead cat bounce."
Do you mean that the accelerating ICE flywheel creates a moment that loads up the rear end and calms it down, whereas an electric motor doesn't do that?
@Judaslefourbe , @Tuner -- Any insight as to why Altas tent to teeter-totter when skimming the whoops instead of flowing straight?
I have experienced this on every Alta suspension that I owned, and I've also seen it when Josh Hill beat RC. I thought he was going to get stuck in those whoops.
Tuner
El Sobrante, Ca.
Low and centralized mass encourages the front and rear wheels to rotate around the mass center prompting the for and aft rocking. Most off-road motorcycles are rear weight biased, where the Alta is near neutral, particularly while standing on the pegs. Lack of significant rotating motor mass also allows for more pitching as a result of rapid motor rpm deviations during limited and / or inconsistent traction.
Low and centralized mass encourages the front and rear wheels to rotate around the mass center propting the for and aft rocking. Most off-road motorcycles are rear weight biased, where the Alta is near neutral, particularly while standing on the pegs. Lack of significant rotating motor mass also allows for more pitching as a result of rapid motor rpm deviations during limited and / or inconsistent traction.
Wow, thanks, Dale! This all makes sense now. I remember test riding a RMZ450, an Husky 350, and especially a 150SX on the same day and track as my Redshift. The RM and especially the SX felt way taller and way shorter than the Alta. I felt like I was going to wheelie or go over the handlebars. But I didn't, and all these bikes skimmed the whoops and other bumps very straight.
  • Like
Reactions: Rix
Tuner
El Sobrante, Ca.
I had the MXR on a cornerweight scale: Front 61 rear 60 kg!
Most MX / SX motorcycles feature roughly a 60 RR / 40 FT weight bias. The long wheel base also encourages pitching though that is something that most modern single shock chassis's must also contend with. Long, tall with low centralized mass = a rocking couple.
Rix
Fallon NV
I coined this "The Magic Factor" as the Alta feels different to me in the woops than any other MC I have ever ridden.
So, perhaps, not lowering but raising the CG on the Alta would make it better for some tracks...
This is also the reason why I feel like I always have to either pull or push on the handlebars when riding an Alta.
  • Like
Reactions: Rix
ElectricMoto
Sweden
Hmmm, Weight distribution is one thing but I do think a normal ICE (Crank, Counterweight, Shaft, piston, gearbox...) have a very different Gyroscopic physical effect than the electric motor/ reduction gearbox has). I have been involved in a project where we got a bike with too good CG (centre of gravity) and it did feel really weird to ride
snydes Alta powered Honda Grom Videos 15
snydes Honda CR Electric stuff Videos 0
J another Honda CR-e build?, nope its a Suzy! DIY e-Motorcycles 7
