- Connecticut
Ctrl-H will show the hidden folders in Ubuntu
Brad's problem was that he created a "Firmware" directory rather than "firmware". Ubuntu is case sensitive. Make sure the directories and file names are lower case!
Ah, an easy fix when you know what you're looking for! I feel your pain, Brad! TCMB371 has had to bail me out before, Ubuntu is not easy for older folks......
For the record, should anyone experience a frozen display or a bike that is non responsive to any buttons or key turns, disconnecting the low voltage plug from the battery for about 20 seconds and plugging back in will help resolve it. This is the smaller plug on the top left side of the battery. NOT THE ORANGE PLUG. (thanks to Rakesh for the tip)
Is it still possible to get the MT up and running if I tried it now? I take it the chances of getting the cables might not be great at this stage?
Also, I want to share a few hints for anyone else planning to install Multitool in VirtualBox for Windows:
If you install VirtualBox Guest Additions after installing Ubuntu, you don't have to jimmy with the display resolution. You can just resize the VM's window, and the resolution will change to follow the window-resizing. Installation of Guest Additions also enables easy sharing of folders between Windows and Ubuntu.
Instead of manually typing all of those commands during Python and Multitool installation, you can use the up-arrow key to bring back previous command lines, then use the left/right arrows (and Ctl-B, Ctl-F, Alt-B, Alt-F, etc. if you're accustomed to Emacs keyboard navigation) to move around and edit the command.
If you have Hyper-V enabled in Windows 10, you need to disable it before running VirtualBox. VMs in VirtualBox won't run if Hyper-V is enabled. (And you can't run Multitool within a Hyper-V instance of Ubuntu, because Hyper-V doesn't allow non-Windows guest OSes to access USB devices.)
Just running through the instructions before installing. Is there a needto download the Windows CAN-USB drivers, or are they needed in this setup?
Hi
I have just bought a brand new MXR 2018 included fastcharger, which im waiting to get shipped to Denmark....yeah cant wait!.
My question is if the CAN/USB adapter which is needed to get the multitool running, comes with the bike or i should buy it seperatly?. I already purchased the Alta port cable, but i wasen`t sure if the CAN/USB was included with the bike?.
Thanks
Finally got Multitool running, and everything is working well. Ran into a few hiccups with installation of VirtualBox. I bought a used laptop (Yoga 11e) to be my Alta laptop. Had to turn on virtualization in BIOS before VirtualBox would work. Also, disable Hyper-V in Windows or it won't work either. My biggest hurdle was Windows would still not recognize that virtualization was enabled in BIOS while I only had a measly 4GB of memory in the machine. (What do you expect in a $50 used laptop?) I upgraded this to 8GB, and everything started working, and virtualization was enabled in Windows as expected. Not super fast, but good enough to do the job. So, just thought I'd throw that out there for others installing VirtualBox on Windows.
I actually had quite a bit of anxiety about plugging the laptop into the MXR once I got everything setup. I really didn't want to know if the battery might have a fault, since this is an early 2018 MXR (#361). Fortunately, it does have the current firmware (I had the dealer flash it before I bought it), and it hasn't shown any faults so far after 200 miles. It does have one moderately suspicious p-group (mod 0 - P11) that I'm keeping my eye on, but won't know for sure until I run the battery down a bit and hook the charger up to it. In the meantime, I'm praying to the Alta deities for a strong wirebond, and also to win the lottery so I can buy more Altas and parts for Altas.
Big shoutout to Bryan for putting together the most excellent instructional videos! Super thorough and excellently structured tutorial. If David Attenborough did voiceovers for electric dirt bike and computer installation videos, I'm sure it would be like Bryan's videos... Only with David Attenborough. Well done @TCMB371 !
The CAN/USB adapter is not included with the bike. You'll need the adapter, and the data port cable (Thank You for the purchase!), to connect to the bike using the Multitool software.
Good luck with the bike!
SB Moto ABS wheelie bar install / test | Brakes | 6 | ||
My MXR to EXR conversion / lighting install | Accessories, Plastic, Lights, Bling | 25 | ||
Screen protection for SM and all other bikes. Easy install. | Alta Redshift -- General | 18 |
