Post Your ***STOCK*** Stark Varg Suspension Clicker Settings!
Chief Happiness Officer
Post Your ***STOCK*** Stark Varg Suspension Clicker Settings in this thread!
My ***latest*** settings are in my 3/26/2025 post.
I got my Stark over a month ago. The dealer or the factory had a few clickers slightly off, and I so wasted a few practices figuring stuff out. Eventually, I set the clickers to the factory default, but I still hated the Stark. I missed the confidence and predictability that I had on my Alta. I was at a point when I was regretting not bringing the Alta to the track too. Riding the Stark was not fun.
I recently expressed hope that since the stock Stark suspension has plenty of clicker adjusters (4 in the rear!) with some clicker tuning the suspension can be made rideable. I was right!!
Last week, @DonCox and I went to Glen Helen. There, @Bob Casper and his son Casey, who is a pro and a magazine test rider, watched me ride the Vet track, then checked and set my suspension ride heights and clickers.
OMG! My stock Stark with its original wooden suspension that had no feel/give/traction turned into a tame, soft, easy-to-ride, vet-friendly, and fun toy.
RiderWeightSkill LevelPrimary Riding
Philip195 w/o gear, 225 with gearIntermediateMotocross
FRONT SuspensionFactory Default for 90/95 kgPhilip's Settings (by Casey Casper)Delta from Factory
Top Clickers - Comp Low1017/18+7.5
Bottom Clickers - Reb Low1214/14+2
Fork legs above the triple clamp2.5mm5mm+2.5mm
Front tirePirelliBridgestone X31 @12psi
REAR Suspension
Silver - Comp Low1216+4
Blue - Comp High1412-2
Red - Reb Low1010
Bottom - Reb High1515
Rear Sag105105
Rear tirePirelliBridgestone X30 @11psi
Feedback:
A HUGE improvement over stock.
Great front and rear traction. I can run tighter off-camber lines around the track.
Predictable understeer in corners. Easy to follow berms. Easy to turn tighter with brakes.
Leaning the bike into the turn immediately sends the rear tire into a slow slide and makes the bike turn.
Softening the front compression by 1 click makes the bike turn easier. Stiffening by 1 click adds high-speed stability.
The front still sits a bit high. The handlebar still feels too far back and has a wrong bend.
The bike feels very soft and too nice. I might need stiffer springs, LOL!
Here are the factory suspension settings for your reference:
I’m using the stock settings but I am just riding dirt trails with zero airtime so far, 😆
Only have 150 miles on it but the suspension feels better. Any recommendations for dirt trail riding?
I ended up getting 80-85kg rating to get the spring down for trail riding softness. I weigh 89kg plus gear.
The bike is incredible in sandy and hard whoops hitting the front wheel on the peaks or jumping from one to another sometimes.
A think it's a bit too hard still everywhere else but I'm coming off a 2021 Te250i. Apparently they are soft stock.
Following for trail riding clicker advice.
Thanks
Thanks
I did similar, I asked for 85kg suspension even though I'm 95kg (I ride mostly enduro). However, I still got the 5.0n fork springs. I have just had the fork and shock revalved, the valving was a big contributor to the stiffness, the valving alone has made a much smoother ride.
I believe you have to specify 80-85kg to get the softer spring.
85kg you get the 85-90 harder spring that is on the higher weights
Funny , I spent a day and came up with very similar clicker adjustments. First ride my neck hurt from the jarring landings 😝 . Clickers and couple days much better ride. Springs to my weight as ordered with bike. I thought that I would have to valve the bike as I have previous bikes- KYB yz450. I honestly think no valving changes necessary on the moto track- at this point- still getting feel for the bike.
Signed up to resurrect this thread to say thanks for the starting point (and say hi to @DonCox). I had a couple "family rides" on the Stark early on, but in the last couple weeks I had a couple more spirited runs in Hollister and downhill braking bumps at speed were hard to hold onto. Philip's settings brought that into a window where I'm not counting down the seconds until the bouncing stops. I'll probably fiddle a bit more with the shock settings, but a couple rings around Jay's Way and Peats Path even in their current whooped state are plenty bearable now, if you're in a proper riding position. As a side effect, loosening up the front end causes the bike to more naturally pop over big rollers like Lake Rd instead of trending towards tail-high nose dives. Plenty worth the minor loss of corner exit stability if you're ham-fisted on the throttle.
Hello Paul. Are you enjoying the new Stark. Steve Agular got his new Stark also. Ron Shuler at ESR did some really good stuff on his suspension, give Steve a call or get in touch with Ron at ESR fuellerr@aol.com 760 9818802
Thanks, Don. The bike's good. The learning curve is not as steep as I would have expected, and there's still some adjustment both I and the bike need to do, but we're becoming fast friends. I think I want to get a bit further along on this curve before I do a full re-valve. Right now I feel like it's probably within the range of the settings to get something that's super usable, and I want to see how it responds to the seasons changing (and a couple more types of terrain) before I commit to a real directional change on the character. Thanks for the info though!
Hi Philip,
Thanks for settings! Looking forward to trying as soon as it warms up.
Any other changes or insight since then?
On fork height, some say 5mm will make front end less stable all around ? And one person likes 2mm as he is a rear steer guy.
I know it's subjective just wondering if your still running 5mm .
Thanks!
Hi Philip,
Thanks!
I am still running 5 mm. I do not change such things often.
