- Lake Havasu City, AZ
Ah... so this is where all the water collects after pressure washing! Many small mosquito ponds, nature conservation area.
Interesting ideaI used a couple of Chicago screws to replace my failed inserts.
I like them! The knurls are much more defined too.
This is not an entirely true assumption, every melt/freeze cycle will degrade the material, and the more heat used per melt, the faster the degredation. The thermoplastic will become more brittle each time it is heated and melted, but for a small number of melt cycles the effect will be minimal.But then read that ABS is easily re-melted and formed without any changes to material properties.
As a machinist in a former life, I like this fix.I had problems and took a different approach. I drilled a cross hole 1/16" diameter about 1/16" away from where the bottom edge of the brass insert would be located. I inserted a piece of 1/16" brass brazing rod into the hole going through the end of the insert and locking it in position. Problem solved and all that shows is the tiny end of the brass rod. One potential problem is if drilling too near the surface end and the mounting bolt gets drilled. Measure carefully but it is an easy, permanent fix.
Whose idea were these? The only permanent fix I have found is to drill 7/64” holes perpendicular to the insert (at least 3 of them at 90* intervals) through the plastic and into the insert and then put them together with JB weld after cleaning everything with toluene.I too am experiencing the brass inserts pulling out of the rear fender (I will spare you the picture). I also noticed that the subframe brass inserts on the right side are cracked. Not sure why/how this is occurring but I am disappointed in the durability of the plastic. I have only 7 hours on the bike and it looks like it will not be long and I will need a new rear fender and possibly a subframe. I hope they revise the plastic soon and replace it with something a bit more dirt bike worthy.
While I am on the topic of plastic, the side number plates are also very flimsy as they have no subframe support behind them. My right side is already showing signs of cracking. On an ICE bike, one side had the muffler to support it and the other side met up with the subframe. I really don't what to have to keep buying new plastic all the time. On my last bike the plastic would last for years.
