TokyoMX
- Tokyo, Japan
I am using this one (M10x1.5): https://www.amazon.com/dp/B0CCL4ZRFK/?tag=sce0f-20Do you know the parts number? I don't see it on Stark's web. Thanks.
What size of hex is that? We only have the 13 mm and the 17 mm sizes included in the toolbox provided with the bike, so if it's not one of them (maybe the 13) we'll need to get a ¼" socket, too to use that torque wrench.FYI for all, Stark has updated the drain bolt to hex head. See pic of the new version.
I also wish it had less whining noise. I put in the thickest oil I could find, Valvoline 85-140 synthetic gear oil, slightly overfilled, no appreciable reduction in noise.I guess the straight-cut gears explain the whining noise.
My ears kind of wish they've gone for helical although my wallet would probably disagree.
It is a 13 mm. No additional tools needed.What size of hex is that? We only have the 13 mm and the 17 mm sizes included in the toolbox provided with the bike, so if it's not one of them (maybe the 13) we'll need to get a ¼" socket, too to use that torque wrench.
Yeah it appears they haven’t updated the website. I contacted Stark after I stripped mine. I specifically asked if they changed the bolt, as I wasn’t going to order the same bolt. They confirmed they changed the bolt and sent me a replacement under warranty after I sent them a picture of the stripped one.Thank you. I see the parts number, but shows old style drain plug.
I"ll contact the support. Thanks anyway.
Interesting. When I contacted them about it they sent me replacements of the old style. But I am glad they fixed it. BTW how did you remove your stripped one? I have posted pics of how to chisel it out since I had do it twice.Yeah it appears they haven’t updated the website. I contacted Stark after I stripped mine. I specifically asked if they changed the bolt, as I wasn’t going to order the same bolt. They confirmed they changed the bolt and sent me a replacement under warranty after I sent them a picture of the stripped one.
I used a Dremel to cut a slot in the head from 9 o’clock to 3 o’clock. Then used a flat blade screwdriver angled up at the 3 o’clock position and tapped it with a hammer. Bolt spun free easier than expected, which really makes me think the bolts were/are just really soft. My bolt was definitely not over torqued and I was very careful using the correct bit, lined up straight and it still stripped.Interesting. When I contacted them about it they sent me replacements of the old style. But I am glad they fixed it. BTW how did you remove your stripped one? I have posted pics of how to chisel it out since I had do it twice.And thanks for your post BTW!
I used the right size torx and actually used different bits which were new. I think you touched on it somewhat, the machining on the bolt itself was poor and the material was very soft and subject to heat and different material mating. That Stark changed the design of the bolt (which is a good thing) speaks to the problem I think.I changed my oil for the first time last week (6 hrs, no silver solution at all, oil looked pretty fresh, though I have not ridden it hard all). I had zero problems with the OEM plug. I'm a machinist fabricator kinda guy for over 50 years so I've faced plenty of persnickety fasteners....hard for me to imagine all the problems folks have had with this one if the right torx size is used. I wonder if some went out with a poorly machined torx socket...or maybe over tightened at the factory.
Same.I used a Dremel to cut a slot in the head from 9 o’clock to 3 o’clock. Then used a flat blade screwdriver angled up at the 3 o’clock position and tapped it with a hammer. Bolt spun free easier than expected, which really makes me think the bolts were/are just really soft. My bolt was definitely not over torqued and I was very careful using the correct bit, lined up straight and it still stripped.
Yea that was my concern, some companies will off load the remaining stock they have to they don’t lose money. This may just be a fluke, but i’m sure you will get the new bolt at no cost, just the inconvenience.@Foss FYI I followed up with Stark sent them the picture of the new bolt and said that was what I wanted. And they said their site had not been update with the new pic and I would get the new one.
Bolt came today and sure as shit it was the old one. Glad I only ordered 1. Resent another mail saying they sent what I didn't want. Will post when I hear back.
Now for someone to place a new order to put this to the test lolHi All, Happy to report Stark got back to me and said sorry it was a mistake and that they would send me the update bolt... Very happy with their fast service.![]()
Still waiting on my order.Anyone order the new plugs and receive the new design yet?
There is an Allen wrench plug on Amazon that fits (see post #142)Still waiting on my order.![]()
H | Varg Skugga - for the shadows | News & Press Releases | 4 | |
C | Uk Varg insurance ?! | Stark Varg -- General | 0 | |
J | Tarrifs...How will they affect Stark Varg EX pricing? | Deliveries, Production, Dealerships | 3 |
