- SW Montana
Max hp is based on the motor and programming of the controller. It does not automatically change just by increasing the battery size. A larger battery has the potential to allow a larger draw with less damage than a smaller battery. To increase available hp max, it would require different controller programming at a minimum and possibly a different controller and/or different motor. The 80hp version already pops up a warning. I thought that used to be about how hard it is on the bike, but just saw a vid that showed it saying it was just a lot of power (liability thing or just being cute?). But the faster you draw power, the harder it is on the battery. The 10% large battery (going from 6.5kWh to 7.2kWh), if nothing else, will be less impacted by the faster/larger draw on the battery. If not due to the cell construction, at least because the draw is a lower percentage of overall battery capacity. Same for charging rate.I’m talking about the new batteries in the enduro model. How does range increase 20% without the max hp also going up?
All things being the same, a larger battery will give you more range, but max output (hp) will not change without reprogramming.
