EX Custom iOS/Android App
brongle
WA
I briefly shared some details on this in a thread about extracting soc data but I've built an alternative app to the stock Stark one. This app runs on both iOS and Android while supporting most of the stock app features except "writing" configuration data like maps, charge rate, and other bike settings (these may come in the future). In addition to the stock information the app also provides access to all of the diagnostics data the VCU provides. This data is normally recorded during rides and uploaded to Stark via the phone, however it's obviously very useful to have this information available for end-users and dealers. Long term I have no clue whether Stark will try and prevent third-party apps from accessing VCU data, however as the app never writes data to the VCU it shouldn't void your warranty in places with strong consumer protection laws (at least in the US I know your fine). I am hopeful they see the value in third-party support and have an overall mentality of right-to-repair, but they could choose to brick this app in the future if not.
Some important notes:
- Only a single device can be connected to the VCUs Bluetooth interface so you can't use both the Stark app and this app at the same time. Because the Stark version is so aggressive with trying to maintain a background connection to the bike, its easiest to move it far away or turn it off when using the alternative app version.
- The app doesn't require your Stark login but instead connects directly to each EX bike. I was actually surprised this was possible as its a very insecure method of communication to a VCU, but in our case it means you don't have to worry about using your login credentials. For dealers or owners of multiple bikes this may also be useful since you don't need to swap around Stark phones.
- Ride's are not tracked or uploaded to Stark when you use this app which may be a benefit or a downside depending on your use case. This means the main hour and odometer counters will be incorrect, however the ODO displayed on the dashboard when the bike is on comes from the VCU and will remain accurate.
- Much of the telemetry and diagnostics data isn't used in the Stark app (some of them are on an internal engineering view) and thus required me to make some informed guesses around what unit, scale and format values are in. I'm still working on accurately computing some values like amps and watts used through the motor/inverter.
- Using a more modern phone that has a much better Bluetooth chip means the connection between the bike and the app is much more reliable. In 2500 miles / 100 hours of using the app I've never had a single connection issue to the bike.
At the moment the iOS version is going through the Apple review process, so I'd like to find a few beta testers (I believe I just need the email address attached to your apple account to send testing invites) that are interested and willing to provide some feedback. Just send me a DM with your information and I'll add you in once the review is approved. The Android testing and release process is actually a bit more annoying/extensive so I'm waiting to do that until I can get the iOS version released. I plan to release both apps for free once the app-store review process completes.
Here is an example of some of the functionality, there is a lot more data provided within this app but it all requires a bit of thinking and knowledge to use, so I'll leave that for people to explore on their own.
(kw value is totally wrong in this screenshot)
And finally this is a 35 minute cut of a (street-only) ride I did with the app displayed as an overlay the entire time. This is an older version so not everything is perfect but should still give you an idea of how it works in comparison to the stock version.
Bernardo
bravo! i‘m loving it.
i‘ll be a beta- tester.
but… i read the general terms from stark. will they be happy?
they also mention the ability to shut down the bike remotely when someone mess up with their
intellectual property.
no idea if that ever happend or will happen??
brongle
WA
The app doesn't behave any differently from the VCU perspective compared to the stock version. Stark's terms are pretty broad but at least in the US reverse engineering cannot be restricted. I imagine in the EU there are similar standards for allowing users control over devices they own. As to Stark's ability to remotely brick vehicles, I'd offer two main points:
- In the US this is definitely illegal (for vehicles) as it violates consumer protection laws. Tesla for example has had some massive liability issues related to remote access and remote disabling of "ignitions". Stark has only done this so far based on financing/theft situations which is the one exception.
- PR wise Stark's previous actions have already been a disaster even though they where arguably justified (and not breaking any laws) by locking the stolen/misappropriated bikes. If they start bricking bikes for reasons like this people are going to be even more upset.
I'm happy to remain the guinea pig for the time being (and given Stark now knows this is happening, they could easily track me down if they wanted :)) but its definitely an "at your own risk" type of situation.
Did you try to contact Stark?
As you say, now it's going to be official, if you get approval from Apple, Android stores, Stark would obviously know about it.
Might as well see what they think about it?
I personally think it could be a great advantage of EV if you're able to tune your dash and get more infos out of your VCU, hopefully they can see some value in this too.
I think you should contact Stark, and I would bet that if they're smart, they would either offer you a job, or at least some sweet sub contracting work. I dm'd you to be a beta tester. Do you currently have any apps in the app store?
Congratulations on what you have built!
Great job!
I'm really interested in the speedometer based on the gear ratio. As I've changed the gearing of my bike for both my dirt wheels and SM wheels, it would be nice to know what my speed is instead of guessing based on a percentage change I've roughly calculated.
Is this a feature that's build into the VCU stock or a layer you've added for the speed display?
I'd be happy to test the android version when that becomes available or if you have an APK you are willing to send
brongle
WA
Great job!
Sadly not built into the VCU which just gives the calibrated speed (in kmh and using their static drive-ratio) and the motor RPM.
brongle
WA
Can it reliably lock/unlock?
I haven't implemented any of the "writing" to the VCU functions like lock/unlock or charging/map config for a few reasons. There is a bit more risk to bricking the VCU once I'm writing data to it even if I keep things identical to how the stock app functions. There is also an issue of access since Stark's app uses the account as a way of "gating" vehicle access (e.g. proving someone owns the vehicle sitting in front of them). With my version you'd be able to walk up to any locked bike and unlock it (or if implemented edit the maps/other config) which is sadly the standard of security Stark has chosen here.
Hinkelstein
I think not to write into VCU is more a plus than a missing feature. Just beeing able to arrange speed, Battery Cap and mode would be very useful. Maybe as an overlay for android nav apps or as a nicer dashboard (maybe something thats also showing the time ;-) on ios. The readings of the bike parameters of course is a plus too.
brongle
WA
Thanks for those interested in testing! I'm still working on getting the test build approved, it has to go through Apple's review process and that is sadly complicated by the fact the app interfaces with a Bluetooth peripheral. Apple requires a video of the app being tested alongside the peripheral, but for some reason the one I sent was not good enough and they don't give you a clear reason why. I'm going to try again this week and hopefully I'll have some better news.
Hinkelstein
what about android? Imho one great use of your app would be an overlay with speed, battery and mode over a nav app like locus or dmd. As far as I know this would'nt be possible with IOS?
brongle
WA
Android will come after I finish getting the iOS version released (unless things really get delayed), purely because I've been actively using and testing the iOS version. While around 95% of the code and functionality is shared, some minor details do have to be sorted out on in a cross-platform specific way so there is still a bit of work to do.
It's also worth noting that running the app on the Stark phone may prove to be difficult. The stock Stark app tries very aggressively to remain running in the background and will continuously try to connect to the bike. As the VCU only allows a single connection at a time this will probably mean you have to kill the Stark app in the settings and then within a minute launch the third-party app (before the Stark app notices its not running and relaunches). It'll work but still probably a bit of a pain for people that just want to swap back and forth or use the stock phone with the custom app.
That does sound like a challenge. I would prefer to use the stock Stark phone to run it on, purely because the mount holds the phone so well onto the bike. The Varg app is aggressive, it won't even let me turn bluetooth off, just turns it straight back on.
