EX Custom iOS/Android App
brongle
WA
I assume that accuracy would be influenced by tire size and sprocket size combinations.
I’m not sure what to make of the “odo” number of 131.
Here’s the stats from the Varg phone.
My next guess would be maybe the 1.2.8 firmware was the first version on the MX that tracked mileage on the VCU? I'm not sure when you updated or if you remember how much you've ridden since but if its not that then possible the MX version just doesn't have a proper built-in odometer. And yes it is influenced by the gearing and wheels, won't be too bad but definitely requires some thinking to convert the VCU odometer into a more accurate number.
My next guess would be maybe the 1.2.8 firmware was the first version on the MX that tracked mileage on the VCU? I'm not sure when you updated or if you remember how much you've ridden since but if it’s not that then possible the MX version just doesn't have a proper built-in odometer. And yes it is influenced by the gearing and wheels, won't be too bad but definitely requires some thinking to convert the VCU odometer into a more accurate number.
I suppose it is possible that could be the mileage since the firmware update, but seems too big…?
I guess I’ll watch how it increases, and that should help understand what it means😎
