Very interesting.
Considering 75% of 7.2 kwh, i. e. 5.4 kwh, in in 45/60 minutes, it must be indeed charging at more than 5 kw.
Pretty weird that Stark hasn't sent any email about this update.
I'd like to know whether there are signs of burns on the pins of the Schucko plug, though.
That's just the time that Stark Future will guarantee the bike; it can last a lot longer depending on usethat number concern me a lot, i already have 160 hours on just 5 months of use, and the limit is 500 hours? so the bike wont last me even a 2 year lifespan at this rate? and i dont even use It that much, some trails every other weekend and 2 days a week for work... i cant believe that
Interesting. What charger/s are they using?A friend of mine, actually charged at 6.6kW and it's working for him, it's drawing 5.9kW and he charged from 10-85 in like 45 min to an hour View attachment 15087
On my EX it shows the same now, but as OpaTsupa said this is on an outlet with a 16A fuse - do the math, it is not possible. It is a software bug.Interesting. What charger/s are they using?
are you sure is only on "competition use"? doesnt say anything about that on the manual, but i believe you, i don't want to believet the opposite because then my bike has a little more than half of its life left and I'm practically starting to enjoy it now, I don't like spending 13,000 euros on a bike that won't last me even 2 years... I don't use it for competition but I also do my little jumps and do light enduro I suppose that will wear the bike down too... but oh well, hopefully with this use it will last at least 1,000 hours... I think that what suffers the most is the battery and the chassis, the rest you can replace everything "cheaply". The inverter/motor should last a lot more than 500hoursThe bikes expected life where the bike functions as it should at the expected use is 500 hours.
Same for the MX.
That 500 hours is competition use. Jumping, bashing, racing. The stress to the frame and everything around it in MX or Enduro competition is something completely different to what you are doing.
You will see claims like this at any bike, especially MX and ENduro bikes.
so the Stock Charger is capable of 6.6kwh WTF! jajaja . I am worried that both the cable and the connector could burn, but also the charger components themselves.A friend of mine, actually charged at 6.6kW and it's working for him, it's drawing 5.9kW and he charged from 10-85 in like 45 min to an hour View attachment 15087
We need to see what Molicell has to say about all that for their cells... seems legit. i ALWAYS charge it at the 1kw slow mode or even less sometimes... i use 3.3kw just one day because my friends called me to ride and i was at 30%. Im treating the bike like a baby jajajaI remember having read somewhere, I think from some Stark's document, but don't quote me on this (I mean don't quote me unless you are replying to this post) that the battery was supposed to experience a continuous reduction in capacity up to the point that, after 500 full charging cycles, its capacity would have been 80% of the original one. This means 5.2 kwh for a 6.5 kwh battery and, if the statement holds good for the 7.2 kwh one, 5.8 kwh for it. Full charging cycles means from 0% to 100%, so if you recharge for example by 50%, then it's only half a full charging cycle. BTW, the percentage of original capacity left is named State Of Health (SOH), so when you reach that point of 80%, then the SOH is 80%.
This degrading process is affected by the use conditions: how fast you discharge, how fast you recharge, how well balanced the cells are, etcetera.
Now the slider reaches 6.6 on my phone, too on a Gen1 MX 1.0 although I haven't manually updated the app since one week ago, when I could only set it up to 3.3. I don't dare to try it until Stark explains us how we can use it. At the tracks where I ride, they have dozens of kw of electric power available and I've also seen some of those red industrial sockets that usually are rated at 380V and a lot of Ampere, so maybe they will let me recharge faster, but I still want to understand what charger I can use with that power and any limitation, because more than once I've read things like "max 250V 16A" for schucko connectors and never anything more.
Offcourse hard to say but any statement about a competition bike is made in regards to competition use.are you sure is only on "competition use"? doesnt say anything about that on the manual, but i believe you, i don't want to believet the opposite because then my bike has a little more than half of its life left and I'm practically starting to enjoy it now, I don't like spending 13,000 euros on a bike that won't last me even 2 years... I don't use it for competition but I also do my little jumps and do light enduro I suppose that will wear the bike down too... but oh well, hopefully with this use it will last at least 1,000 hours... I think that what suffers the most is the battery and the chassis, the rest you can replace everything "cheaply". The inverter/motor should last a lot more than 500hours
My MX 1.0 also shows 6.6 now. However tops out at 3.1kW like it allready did before. Have to mention it has been charging with 0,3kW for a couple of hours now. Might be the charger being hot.
Damn i guess it means i really should get that EX. Just extended my warranty with 2 years today. But hey, can't be all that bad of a deal.
Based on my experience so far the battery degredation will be exactly on-par with what we expect, around 1000 cycles should be somewhere between 80-90% of the original capacity.We need to see what Molicell has to say about all that for their cells... seems legit. i ALWAYS charge it at the 1kw slow mode or even less sometimes... i use 3.3kw just one day because my friends called me to ride and i was at 30%. Im treating the bike like a baby jajaja
BTW, tomorrow i have my local dealer changing my entire drive train, i hope they do it quickly, the entire motorcycle needs to be disassembled for that, terrible... i want to do it myself but Stark says i will loose the warranty
I only had it connected for a few minutes, and it was charging noticeably faster than at 3.3kW. Charger fan came on immediately, unlike at lower power settings.On my EX it shows the same now, but as OpaTsupa said this is on an outlet with a 16A fuse - do the math, it is not possible. It is a software bug.
Exactly, that's my point of view as well. I have the spec sheet and I have seen the wiring Stark uses inside the charger setup. 5.5kW would be like 50% over spec and using components that more powerful than speced without advertising/utilizing just wouldn't make sense.It's curious as to why anyone with the current Stark model EVPT23-32010 charger would get more than its rated output of 3.3KW.
I have a clamp meter for amperage so that should be able to shed some light on the issue.Do you have a method to monitor power output before the charger?
