Maximizing Range for the Stark Varg
Raindog
WNC
If those 60 miles have been measured with the on-board odometer, and if that odometer works measuring the rotational speed of the rear wheel as I suspect, then the 60 miles value has been affected by the different size of the rear wheel.
Well, it's twenty-two miles from my house to work. When I pull into the garage at the end of the day I usually have 29-31% charge left on the clock.
Raindog
WNC
I assume you are using some other odometer besides stock, which reads the rear wheel? Racetrack or commuting?
The speedo uses gps, there's no pickup for a traditional gauge and I'm not sure why anyone would want one. I commute on the bike during the week and mostly run the BRP on the weekends.
I could run a smaller sprocket on the back and maybe pick up a few miles if I ran interstate at sustained speeds but that's not how I use the bike. I'm in and out of the throttle on tight backroads for the vast majority of my daily commute.
I did a 200 mile day on my 2t motard a few months back and by the end of the day I was wishing I had taken the truck. :)
On this past Sunday I got 15 miles of slow mostly single track with some Enduro gnarly hills used about 35% battery. So I could comfortably get the same as @Johnny Depp in the slow gnarl.
I am mostly stock with my newer Varg. Some Acerbis parts and an AXP skid plate still running the Pirellies (with IRC heavy duty tubes) till they are worn out, they don't like the 8 psi...
:ricky:
brongle
WA
Speedo is based on motor spin not GPS, it will be inaccurate if you change gearing or wheels.
vic321
I don't think you will get better range in hard Enduro with taller gearing. The wheel/motor speeds are so low you will stay well in its operating area.
There is plenty of torque on tap, but not a lot of power at crawl speed in sensibel horsepower modes. And in the end it's power that moves you, not torque.
That results in a ''slowish'' reacting bike when rock crawling with tall gearing. Offcourse you could just add hp so overcome the lack of power down low. But when it then whiskey throttles it's off to the moon and when doing steep hillclimbs that power puts you into wheelspin or backflip scenario's rather quickly.
No, its always torque that moves you. Horsepower is just a mathematical construct. Therefore HP is always abysmal in low rpm. By changing the gearing you always change torque, never the HP.
Torque is a stationairy force Nm. The amount of force that's needed to move an object is power in J or W (or HP so you will).
By changing the gearing you change the amount of HP per revolution of the rear wheel by changing the Torque part of the Formula. HP = Torque × RPM / 7023. Change the Torque at the rear wheel at the same wheelspeed (actually what you do when changing gearing) and you have increased/decreased HP.
vic321
Nope, you do not. The HP stays constant. HP= Torque*rpm. Simple math. you change gearing to 1/2", then you raise torque by doubling, and rpm by half. The multipilcation keeps the same. There is no way to change HP by changin the gearing.
What you suggest is to double the rpm for the engine per turn of the wheel. That has a limit in the rpm range of the engine. Nevertheless the effect you get is from larger torque. If you got more than enough torque from the engine from 0rpm on, these kind of games become meaningless. With the Stark you get much more torque (and HP) from the standard gearing, than you will ever get from changing the gearing on an ICE bike. Without the rpm limitation. A traction control would be much more handy.
The maximum amount of HP stays the same yes, the Torque will double as well. But the top HP will come at 1/2 the wheel speed since the motor will be running the same RPM at top power. Agree?
So as established above you have now lowered the amount of revolutions of the rear wheel needed to achieve max HP (or any HP).
Same goes lower in the wheel speed range. You now have double engine/motor RPM at any given range so you doubled (lets assume this is a simple straight line motor for this example) all HP per wheelspeed below top HP wheelspeed. Above that you are actually loosing, but if that's a speed you cannot ride or don't want to ride that's fine.
vic321
No, the top of the HP is always at the End of the rpm. With the Stark. And near the end with other bikes. Because the torque curve is always wuite flate over the range. Completely Flat on a Stark.
