- Europe's arsehole
Maybe I'm more used to the maintenance schedule for motocross, but the cost estimate for your 2 stroke looks too optimistic to me.
If you do 50 h per year, can you just replace pistons for 400 h in eight years? I bought a 2001 YZ250 in 2016, so it was 15 years old. I don't know whehter the crankshaft had ever been replaced, but the conrod had radial play and the left journal had been spinning inside the bearing, so there was no interference with it and its diameter was 0.03 mm smaller than the new crankshaft I bought to replace it. Yes, your bike is much newer but crankshafts don't last forever; usually people say that every three pistons you replace the shaft. Same thing for the crankcase bearings; you'll replace them, then there are shifting forks which wear, gears from the gearbox which may not engage anymore after hundreds of hours. There are also smaller things like clutch discs, the muffler packings, and those things that break from time to time that you can't predict.
Plus, with the Stark it is possible that it will be flawless or that it won't be, while with a 2 stroke it's sure that you will need to do preventive maintenance and quite possible that you will need to do something aside the preventive maintenance and not everybody has fun trying to find the supposed air leak which is making the bike lean, for example. I personally find it crazy that, with ICE bikes, you need to be a mechanic just to be able to ride. At the beginning it was interesting and satisfying to do the maintenance, but after some years it started to be something which steals time to other stuff which has the priority, including riding itself.
BTW, in 50 hours my Stark has needed way less time and money spent on maintenance than my gas bikes and basically with it I've had fun without worries for an year. Others may have had different experiences but that's mine, so far. 8 years from now, I don't know.
On the other hand, if you are satisfied with you Beta and you have that opinion about the Stark, apparently the Stark is not for you, at least for now; you can still buy it or buy another electric motorcycle in the future, when prices will have changed (who knows how for sure?) and there will be more information about them.
Again, I apologise for moving the discussion to cost of ownership and price.
I don't think there is much sense in comparing Varg and 2T 300 in that regard.
My opinion is that people who can afford a 10K bike usually replace it in less than five years, so the long-term (~10 years) reliability isn't relevant.
Also, there is a greater probability that the bike will be destroyed in a hard crash sooner then it will wear out.
I do agree with you about the mechanical work. I too am tired of tinkering, and jetting the bike every couple of months.
On the other hand, I would need the Stark to be flawless because I can not work on it all, and closest dealer is 1000km and three borders away.
