Aren't radial street tires heavier? And they're not of the same dimensions. 17" street wheels may be heavier? Beefed up calipers, beefed up triple clamp, could be heavier forks and shock maybe?i dont understand why it is more heavy even with smaller wheels, same bike... the front disc is 320mm but it dont think it will weight that much
Not really...The dust moto Hightail is the bike it's 220 pounds 42 hp.
I don't think 14/47 with 17s would even get close to 154kmh on the current motor so I wonder how inflated that number is.oh nice explanation guys... but it shouldnt be a problem for Supermoto... husq 701 and ktm 690 are 155kg bikes with 70hp... the varg sm is a beast
The smaller charger is a game changer, im going to buy it when available... phone holder is thinner and more minimalistic, maybe compatible with EX too...
Gearing is 14/47 with 154kmh top speed. Suspension travel is a little big in my opinion, they didnt change de 303mm rear and just cut the front from 303 to 290mm... i think the ktm 690 has 260mm front, anyway...
overall Stark is going in a good direction and this is just the beggining
It's a cleaned up Surron. Unless companies want to develop actual battery technology a 22S pack is not going to compete in performance with a 100S.The dust moto Hightail is the bike it's 220 pounds 42 hp.
You could also just opt for an extra wheel. You can just order that and they're not even that expensive.I agree 100 percent on the unproven platform I'm done waiting gunna pull trigger on the mx 1.2 if I can get a 18 rear tire which I heard I can't so the ex fully loaded.
I doubt it's inflated at all.I don't think 14/47 with 17s would even get close to 154kmh on the current motor so I wonder how inflated that number is.
EX with 17" rear tire does 165 with 15/44 gearingI doubt it's inflated at all.
The EXs top speed is 136. With my back of a napkin maths 14/47 would get me to 162.
Cold you give an example of a 17 road tire and an 18 enduro tire that are close to eachother in diameter?Also depending on the tyre size the 17' doesn't need to be much smaller diameter than the 18'.
Thank you
